5.9 smoking problem
Old Oct 26, 2013 | 01:25 PM
Ramking9610's Avatar
Ramking9610
Default 5.9 smoking problem
I have a 1995 dodge ram 1500 5.9l v8 and when I get on the gas it starts shooting out black smoke which is oil. Also after its been sitting over night and I start it up in the morning it smokes until warmed up. I've done research and it could either be the valve seals or the pistons blowing oil by? Plenum is replaced! Please help!
Old Oct 26, 2013 | 01:51 PM
Black smoke is running rich. Plug in with a scanner, and see if the temp the PCM thinks the engine is, agrees with what the gauge in the dash has to say.
zman17's Avatar
zman17
Retired Moderator - RIP
Oil is usually blue smoke, black smoke usually means rich fuel mixture. Could be ECT .
zman17's Avatar
zman17
Lol!!!
Old Oct 26, 2013 | 01:55 PM
Great minds think alike.
Old Oct 27, 2013 | 10:28 PM
Ramking9610
It's actually blue. Could this be the valve seals?
Old Oct 27, 2013 | 11:02 PM
ryan0714's Avatar
ryan0714
blue smoke is oil obviously, but its a matter of where its coming in. could most likely be coming in due to a blown plenum gasket,m which u could see if you look down into the intake manifold thru the throttle body. but i have also seen oil leak into the exhaust down from the valve covers before. but id check the plenum first.
Old Oct 28, 2013 | 09:00 AM
Plenum has been fixed.
Next logical step would be valve seals, or, simply replacing the heads....
Old Oct 28, 2013 | 05:50 PM
ryan0714's Avatar
ryan0714
i think id would do a compression and leak down test and try to find which valve is lettin it blow by so you can narrow it down, then pull that head, and get some grinding compound and re-seat the valve. and try it again.
