none parkimg wipers
Old Oct 30, 2013 | 12:47 PM
truckguy02's Avatar
truckguy02
New Member
Default none parkimg wipers
help please i have a 2000 dodge ram 1500 ram slt quad cab. the stupid wiper wont park in the down position. low,high, and delay all work fine. they just stop where they are when shutting them off . in order to get them to stop at the bottom you have time it just right. please help
Old Oct 30, 2013 | 12:53 PM
utmkiv's Avatar
utmkiv
Any debris blocking it?
Otherwise sounds like a bad wiper motor.
Old Oct 30, 2013 | 01:41 PM
Matt Nickerson's Avatar
Matt Nickerson
Yup, park sensor is in the motor assembly. So gotta replace the wiper motor. I've had the same problem for 2 years, not worth the $40+ to fix it...I just got used to it.
Old Dec 11, 2013 | 12:33 PM
HeikIlm's Avatar
HeikIlm
So, could that sensor be the problem on my truck, it only has high speed working. Started to act a while ago. When the weather is dry, they work just fine, but naturally when you most need them they just don't work. Also when activating washer wipers don't work.
Old Dec 11, 2013 | 12:36 PM
Time for a new wiper motor.
Old Dec 11, 2013 | 12:53 PM
HeikIlm's Avatar
HeikIlm
Is there anyway to make temporary fix, cleaning the motor or something? It have safety inspection on friday, and hate to have it fail just because wipers act randomly. I'll get new motor anyways.
Old Dec 11, 2013 | 02:45 PM
Not that I am aware of. On the GM trucks, all the smart parts were in the cover for the wiper motor, and it could be replaced separately. Don't think the dodge trucks do that particular trick though.
Old Dec 11, 2013 | 04:30 PM
HeikIlm's Avatar
HeikIlm
Allright, I just placed an order for a motor and water pump for the Cummins. Now that I think of it, wipers were quite slow from the start, occasionally, but after they got moving they worked fine, so obviously that slow motion was a sign of a upcoming failure of an electric motor. Let's just hope that high speed works till tuesday.
Old Dec 14, 2013 | 07:57 AM
HeikIlm's Avatar
HeikIlm
Sweet, truck passed the safety inspection even though the wipers didn't quite work Told the inspector that the new motor is on the way and should be here by tuesday (now it seems to be in France).
