Sky high emmissions and 6 mpg
Old Oct 31, 2013 | 07:30 PM
xjarhead69's Avatar
xjarhead69
Map sensor could cause rich fuel mixture too.
http://en.wikipedia.org/wiki/MAP_sensor
Dave
Old Nov 1, 2013 | 06:24 AM
leahyhfarms's Avatar
leahyhfarms
I think the map sensor is good because when I rev the motor the map valves change.
I will change back to the 195 stat and get a new o2 sensor. I will change one at a time to see if either of them is my problem.
Thanks for all the suggestions.
Old Nov 1, 2013 | 10:17 AM
Ram Driver's Avatar
Ram Driver
Not having a cat will also cause you to fail emissions testing.
Old Nov 1, 2013 | 10:41 AM
Not on that scale. The 6mpg is a sure indication he is running excessively rich.
I have had many vehicles that properly tuned, didn't need a cat to pass emissions.
Old Nov 2, 2013 | 03:46 AM
leahyhfarms
I ve put in a new gates 195 stat. I will post here if this helps.
Plugging into the pcm the o2 sensor seems to be running more lean than rich unlike with the 180.
