ABS/brake light on HELP,
Old Nov 2, 2013 | 07:08 PM
Ramthis98's Avatar
Ramthis98
Default ABS/brake light on HELP,
Well i have problem in my tryck and the ABS and brake light is on aftr i put in
A new rear speed sensor, it work for a few weeks thn came back on!! Any advise? That will be great!!
Old Nov 2, 2013 | 07:09 PM
Is your speedo working? (and I am NOT referring to your bathing suit)
Old Nov 2, 2013 | 07:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand sensor did you buy, and did you remove the negative battery cable before removing the old and installing the new one? Either way, sounds like a leaking brake line along side the gas tank to me.
Old Nov 2, 2013 | 10:00 PM
ryan0714's Avatar
ryan0714
i had a wheel cylinder go out once that tripped the lights also...
Old Nov 2, 2013 | 10:16 PM
Ramthis98's Avatar
Ramthis98
Speedo is working fine, till i replace the speed sensor
Old Nov 2, 2013 | 10:18 PM
Ramthis98's Avatar
Ramthis98
@zman17 i belive its a smp or doorman ...
Old Nov 3, 2013 | 09:24 AM
SMP is usually pretty good. Doorman, on the other hand.... not so much.
Old Nov 3, 2013 | 11:21 AM
Bad_Moose's Avatar
Bad_Moose
Mine does the same thing. Mainly if its moist or raining out, I periodically unplug the sensor and wiggle the fittings and plug it back in and its good for another 3 or 4 months.
I really need to look into it a bit more cause its starting to drive me nuts. Nothing leaking that I can see, going to replace it soon see if that takes care of the issue.
Old Nov 3, 2013 | 02:28 PM
Ramthis98's Avatar
Ramthis98
Yea just took it for a drive and turn the ignition
Off thn turn it on, no lights anymore but i think it will
Come back again
Old Nov 3, 2013 | 03:35 PM
Bad_Moose's Avatar
Bad_Moose
I should have asked if you got the one with the jumper or without.
I was given what was in stock, it had a jumper/pig tail on it.
I finally took it off last week, after crawling under there for the 3rd time in two weeks. Has not coded since, and far as I can tell its just a jumper and I see no real reason for it. Only time will tell, my next step is to just replace it.
