H pipe question.
Old Nov 6, 2013 | 12:18 AM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
Default H pipe question.
Hey guys, basically what I am wanting to know is if I put an h pipe on my true duals, will that sacrifice loudness and tone? Because it sounds like I am going to have to because if my truck is sitting for a little bit at idle it will start running extremely rich and idle down to about 150 rpm's. I am running true duals with no cats and 18 inch glasspacks. My mechanics teacher told me that it does that because I only have 2 o2 sensors and they are only in 1 pipe. That is when he told me to make an H pipe so the sensors can get a reading off of the other pipe.
Old Nov 6, 2013 | 12:29 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You should run an x or h pipe in true duals if you have a Fed.-spec truck.
Old Nov 6, 2013 | 09:41 AM
97tn4x4's Avatar
97tn4x4
I've always heard an h pipe is louder than an x, not sure though.
Old Nov 6, 2013 | 11:00 AM
Won't change the sound at all.
I think I would be more tempted to find out why the PCM thinks that bank is running so lean, that it wants to dump fuel wholesale.
Old Nov 6, 2013 | 11:36 AM
97tn4x4's Avatar
97tn4x4
I had heard that x makes a more mellow sound because of the exhaust being able to cross more freely?
Old Nov 6, 2013 | 01:59 PM
98Dodgeram360V8Mag
Ok thats what i wanted to hear. And i dont know. It has my teacher so confused..
98Dodgeram360V8Mag
A Fed??
Old Nov 6, 2013 | 02:06 PM
merc225hp's Avatar
merc225hp
H pipe will not have any effect on this problem. More like a bad sensor on the motor, does the shop have a scanner? If so plug it in and see what's going on.
Old Nov 6, 2013 | 02:26 PM
dodge dude94
Originally Posted by 98Dodgeram360V8Mag
A Fed??
Federal emissions specification.
And I thought when running true duals on an OBD truck you were supposed to put the front O2 sensor in the H?
Old Nov 6, 2013 | 02:34 PM
That's one way of doing it, but, depending on just how long your H pipe is..... you may or may not get sufficient flow thru it to give the O2 sensor a good reading. After all, the only flow thru there is to balance pressure between left and right banks. (which is to say, not much at all) If your H pipe is only a couple inches long, shouldn't be a problem. if it is more than 6, then you can bet the O2 isn't going to be even remotely accurate.
