Do you have this in your differential?
Old Nov 23, 2013 | 01:11 PM
merc225hp's Avatar
merc225hp
Why would you not use the clips? Not like they are expensive. Links to where this info was posted not to use them, I would like to read this.
Old Nov 23, 2013 | 02:49 PM
jwalkanime's Avatar
jwalkanime
You have the friction modifier in your rear? Clutches need that to operate properly.
Included in the royal Purp.
Old Nov 23, 2013 | 02:57 PM
jwalkanime's Avatar
jwalkanime
I'm not quite sure how I started off in this direction but I think one of the shops mentioned that their carrier didn't include the clips and if I wanted them in it would be extra and they said it works fine without. So I searched the question on google and some threads hit about benefit w/wo. I didn't want to put new ones in with out knowing why they popped out. And, the economy is a hell of a drug...
Old Nov 23, 2013 | 03:16 PM
merc225hp's Avatar
merc225hp
Well the retainer clip has a bigtime purpose. There is a ridge in that clip that holds the clutch pack at a certain thickness, this thickness is needed to make the clutch pack work. Go beyond that allowable thickness and the disks will not be making contact with each other, meaning your lsd will be just like a open diff. Good chances are the discs are already broken again.
Old Dec 16, 2013 | 09:17 AM
JYost1987's Avatar
JYost1987
Have the exact same problem with mine and have yet to figure out what it is!
Old Dec 16, 2013 | 03:14 PM
army_greywolf's Avatar
army_greywolf
What Merc said, the clips are necessary, mine did the same thing, I ended up scrapping the carrier for a trac-lock but still...
Old Dec 16, 2013 | 03:31 PM
merc225hp's Avatar
merc225hp
^^^ +1
I got rid of the 9.25 factory lsd years ago and replaced it with a Detroit locker (not for everyone). I am back to a disc clutch type lsd when I installed the 60's this summer not liking it at all so far this winter.
In short find a better carrier other than the stock lsd.
Old Dec 16, 2013 | 03:34 PM
^^^ +1
What do you have in your 60, and why don't you like it?
Old Dec 16, 2013 | 03:52 PM
merc225hp's Avatar
merc225hp
It would be the factory lsd very much like the one in the 9.25 trac-lok. Why don't I like it, I am not used to each wheel trying to figure out what to do for a split second, I am used to both wheels driving at all times.
Old Dec 16, 2013 | 05:07 PM
Ah, Ok, that makes sense. Thanks.
