Transmission heater?
Old Nov 13, 2013 | 01:05 PM
snowboundrmk's Avatar
snowboundrmk
I've heard that allowing the truck to warm up with the transmission in neutral instead of park helps.
Old Nov 13, 2013 | 03:02 PM
97r/tram's Avatar
97r/tram
Originally Posted by Wildman4x4nut
So why can't it be a 5 speed manual? They offered them??
Because the OP wouldn't be complaining about the transmission shifting into overdrive when cold. Unless his arm was too cold.
Old Nov 13, 2013 | 05:44 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Originally Posted by Twmays
So this morning was the first really cold morning here in Nebraska. Got down to about 5 degrees overnight and my truck's transmission was oh so crabby this morning. Slow shifts, soft shifts, etc. Got better and back to normal as the whole thing finally warmed up.
So I've read a lot about block heaters and oil heaters and recirculating heaters and was wondering:
Does anyone have a oil heater for their transmission?
Does anyone see a need for this in these temps? Or is it just overkill?
No where in this does the OP mention overdrive. I asked what type of tranny in the third post.
Old Nov 13, 2013 | 09:18 PM
lance49726's Avatar
lance49726
You are correct putting in neutral will circulate faster then in park.
Old Nov 13, 2013 | 10:02 PM
moe7404's Avatar
moe7404
OR in rev, cause it raises the line pressure to the highest of any setting. but i would do that only as long as my foot stayed on the brake peddle.
Old Nov 15, 2013 | 02:00 AM
adam8781's Avatar
adam8781
I live in minus 40c/f and at the most all we do is warm up our trucks, or maybe do a cold valve bypass so if the fluid is colder than 180F it wont even go to the cooler it just gets sent back to the transmission. And if people think the rad/stock cooling system will heat the oil, it wont, Ive driven for months and the snow in the fins of the rad won't even melt. Ill bet the thermostat doesn't even open.
Old Nov 15, 2013 | 07:39 PM
gertie240's Avatar
gertie240
150 watts is not very powerful, so it should be good and an old stereo speaker magnet with some butcher twine tied around it for a rip cord would do the trick of holding it up against the pan.
Old Nov 15, 2013 | 10:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
I still like the heating blanket. Just kidding
Old Nov 15, 2013 | 11:12 PM
kyleveilleux1990's Avatar
kyleveilleux1990
how about something like this magnet mount heater ?
its on amazon for 35 bucks. just stick it on the tranny pan and plug er in. when you go to leave just pull it off
Amazon.com: Kat's 1153 Handi-Heat 200 Watt Magnetic Heater: Automotive Amazon.com: Kat's 1153 Handi-Heat 200 Watt Magnetic Heater: Automotive
