Why do you want it to run richer? Do you have the stock intake system on it still? If so it should be running a little more on the rich side. Generally they run at around 14-15 A/F ratio. If you lean it out to around 11 you can make more power. But you'd need to reprogram the computer, and you'd also need a wide band O2 sensor to read it accurately.
