check engine light dilemma
Old Nov 19, 2013 | 11:44 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Remove the cam sensor and inspect it for visible damage. Unplug it and check the connectors for dirt and debris and clean as necessary. A dab of di-electric grease won't hurt.
Check the plug wire routing per the TSB and correct as necessary.
Old Nov 19, 2013 | 11:18 PM
dhvaughan's Avatar
dhvaughan
if it has no issues put a piece of black tape over the CEL light and drive on...
Old Nov 19, 2013 | 11:43 PM
ebxgsxr's Avatar
ebxgsxr
lol. i already thought about removing the bulb, lol.
Old Nov 19, 2013 | 11:45 PM
dhvaughan's Avatar
dhvaughan
black tape is easier to install and easier to remove.
Old Nov 21, 2013 | 05:23 PM
ebxgsxr's Avatar
ebxgsxr
ok. i'm so confused with this thing. i haven't gotten a change to check the sensor. but i thought the light would flash during hard acceleration. but on my way to work, it started flashing just under light acceleration (on one occasion). but still no problems, i wouldn't have even known except i caught the light out of the corner of my eye.
Old Feb 5, 2014 | 07:16 PM
ebxgsxr's Avatar
ebxgsxr
update date on this.....going to need some other suggestions. i had someone check it out. & the only thing he could think is that the coil is breaking down & causing the light to flash on occasions. well, i changed the coil & i still have the same problem. just not really sure where else to go with it. no drive ability problems, runs well. i feel like i have lost a little gas mileage (i thought i used to be in the higher teens, but now i'm in the lower teens pertaining to MPG). anyone have any other suggestions?
Old Feb 5, 2014 | 07:50 PM
Do a compression test.
Old Feb 10, 2014 | 11:34 AM
ebxgsxr's Avatar
ebxgsxr
just an update. a buddy of mine sent me a link to a TSB. the number was TSB 18-48-98. it had to do with re-routing the plug wires. looks like that did it.
Old Feb 10, 2014 | 08:58 PM
ReadRam's Avatar
ReadRam
Originally Posted by Gary-L
A flashing/blinking CEL usually indicates a plugged catalytic converter. The OP should take his truck to a muffler shop and have the exhaust system pressure checked.
I''ll second this guess. Or it's misfiring that can cause damage to the cat.
