magnum to LA
Old Nov 18, 2013 | 11:30 PM
heminutt's Avatar
heminutt
Default magnum to LA
what would it all take to put a 360LA in my 99 ram with a 5.2.
Old Nov 19, 2013 | 07:23 AM
AtomicDog's Avatar
AtomicDog
Why not use a 360 magnum instead? The 360LA has no fuel injection and no hydraulic roller cam.
Old Nov 19, 2013 | 09:31 AM
heminutt's Avatar
heminutt
I have a la motor already
Old Nov 19, 2013 | 09:35 AM
97r/tram's Avatar
97r/tram
You can make the same power building whats there and not have the carburetor issues and fuel mileage problems that you'd have with the la.
Old Nov 19, 2013 | 10:42 AM
heminutt's Avatar
heminutt
what would it take to get close to 400hp cause the LA motor I have is close to 400
Old Nov 19, 2013 | 11:03 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You build the top end.....
And I guess you didn't like my answer on DT. lol
Old Nov 19, 2013 | 12:12 PM
97r/tram's Avatar
97r/tram
And it's gonna take alot more work to get the la to operate using the stock alternator which is regulated by the ecm.
Old Nov 19, 2013 | 12:31 PM
Not to mention all the gauges are also driven by the PCM. Even the friggin oil pressure gauge. And then there is the trans.... which is controlled by the PCM..... If you drop the LA motor in there with a carb, you are going to have to come up with a trans controller as well.
Even though you already have the motor, it would still end up less expensive to build a magnum motor to toss in there, then you can use the existing PCM, and the trans.
