? i thinktorsion bar question
Old Oct 6, 2005 | 08:41 PM
pastfast125's Avatar
pastfast125
Default ? i thinktorsion bar question
aiight...I have a 2000 dodge ram 1500 2wd....does this truck have a torsion bar??? If so can I lower the front end by adjusting it...I've heard that you can lift trucks like 1 inch with it..but I wanna lower like 1 or 2 inches. I know how to adjust it, just not sure if I have one..lol, if that makes any sense. thanks.
Old Oct 6, 2005 | 09:02 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: ? i thinktorsion bar question
No...no torsion bars. That would be something found on a chebby.
Old Oct 7, 2005 | 03:01 PM
Silver_Dodge's Avatar
Silver_Dodge
The new Rams have it though. If you have a solid front axle, you do not have a torsion bar. It goes with IFS setups.
Old Oct 8, 2005 | 12:47 AM
pastfast125
ya I have IFS..but i guess still no torsion since it's a 2000..i have a theory though..but I'm not sure..on the "A-arms" i guess you'd call em..inside there is a recessed shock mount plate for the coil spring to sit on, here's my idea...get rid of that plate and weld in one that sits like 2 or 3 inches lower in the a arm..what do you guys think of that???
Old Oct 8, 2005 | 02:21 AM
The Burning Rom
Yeah...it's IFS...sorta.
Have you looked into other options...such as springs: http://www.drivewire.com/performance...500prokit.html
Or kits: http://www.truckaddons.com/Catalog/s...nd_force06.htm
They'd be safer than modifying your suspension. I've seen a lot of unsafe suspension modifications on many different vehicles. Just my 2 cents...
Old Oct 9, 2005 | 04:51 AM
hometheaterman's Avatar
hometheaterman
Say what? IFS wasn't introduced until 02.
Old Oct 9, 2005 | 05:42 AM
Ramtuff's Avatar
Ramtuff
He has a 2wd, which has IFS. Torsion bars will only be found on a 4wd IFS.
Old Oct 11, 2005 | 01:08 PM
ljpierce_ely's Avatar
ljpierce_ely
ORIGINAL: The Burning Rom
I have to agree with Burning Rom. Do your drop correctly. I own a 98 RAM 4x4 and a "Chebby" S-10 4x4. I raised the front of the S-10 by cranking up the torsion bars, and it caused more problems than I thought it would. Uneven tire wear, skittish steerting, and threw off the steering dynamics. The only way to lift or lower is with the proper kit. Spend the money to avoid the problems.
