thinking about re-gearing?
Regearing just for mpg and no plans for bigger tires is a waste of cash. You are very close to what the truck is supposed to get for mpg.
Estimated EPA Fuel Economy for the 5.9 is (MPG City/Hwy) 1500 2WD: 13/17; 1500 4WD: 12/16 auto.
For the 5,2 it's Estimated EPA Fuel Economy (MPG City/Hwy) 1500 2WD: 13/18 man, 13/19 auto.; 1500 4WD: 13/17 man., 12/16 auto.
What is the powerband HeyYou? I think it heard its between 2000-2200?
I've got 4.56 and at normal speeds I'm at 2100ish with 35s. I used to have 3.55 and drove with 33s for while. Hated it. Took a long time to get up to speeds. Then I changed to 35s and wow.. It would downshift on a straight stretch!!! I went with 4.56 and will never look back. I gained probably 1-2mpg all around. It town it is a lot easier to take off and at highway speeds it revs higher but it's not downshifting anymore.
4.56 and 35's puts you right in the neighborhood of stock RPM/Speed.
Our trucks seem to start out right around 16-1700 RPM, and it pretty good up to around 4K or so. (but, you don't wanna cruise at 4K) I am thinkin' if you keep your RPM right around 2000 at your typical cruising speed, that would probably be right where ya wanna be.
At 55, I am right around 1500 RPM in O/D, and that is just too low so far as I am concerned.... I am looking at doing 4.56, and 33" tires.... which will bump RPM about 200 or so at my typical cruising speeds. I don't do a lot of freeway driving, so, that aspect doesn't really bother me. (currently, at 70 MPH, I am right about 2200 RPM. I think.)
I have 265/75/16s and 3.55s at the moment.
What would be the round-a-bout price to switch gearing from 3.55 to 4.56? I have 33" tires on mine and like everyone else, i have to down shift like crazy to just go up hills and pass people when at speed. I'm not so much doing it for mpg as i am for just less stress on the tranny.
Depends if you buy thick gears or a new carrier for the front. The stock carrier won't work with that low of a gear. I would assume 800-1000 for parts + installation. So probably 1500ish. My install was a little more pricy as I added lockers but I did it myself.
