aux power supply outlet
Old Oct 7, 2005 | 01:36 AM
redneckhunter's Avatar
redneckhunter
Default aux power supply outlet
I have a 2000 quad cab and the aux outlet does not work. I checked the fuse and it was fine but I replaced it since sometimes you can't tell if it is blown. The contacts are clean. Any ideas?
Old Oct 7, 2005 | 11:58 AM
Blackimpala's Avatar
Blackimpala
Default RE: aux power supply outlet
Try using a 12v test light to see if you are getting power on the wire coming into the back of the plug or you could just have a loose connection.
Old Oct 8, 2005 | 02:23 PM
Trippen's Avatar
Trippen
Mine did the same thing on my 97 after a new stereo was put in...Some foolish person....Pulled on it too tight when putting in the unit and it pulled out of the back of the plug....Humm the I am not going to drop a dime on the foolish person...but just let me say this he will never go through the hassle of fixing said wire again.
