Cursed radios.
Old Dec 2, 2013 | 11:11 AM
Need to find a radio that you KNOW is good....... You have good power, and ground, that leaves the radio.
Old Dec 2, 2013 | 01:51 PM
The Griff's Avatar
The Griff
I don't know where I would find another one at though, I have two aftermarket headunits in my garage, one of which I know works very well, but I would have to get the adapter for it.
Unless someone on here has a Mopar to Kenwood adapter.
Old Dec 2, 2013 | 02:05 PM
merc225hp's Avatar
merc225hp
^^^ Buy one not that expensive, I think I paid $10 for mine.
Old Dec 2, 2013 | 02:16 PM
The Griff's Avatar
The Griff
Really? that cheap?
I might just go buy one then.
What about the problem of big hole little radio? The factory radio is much taller.
Old Dec 2, 2013 | 02:24 PM
merc225hp's Avatar
merc225hp
Yep going to need the bezel to match the two up also cheap. Have a look at Crutchfeild web site they should have what you need.
http://www.crutchfield.com
Old Dec 2, 2013 | 03:23 PM
The Griff's Avatar
The Griff
Alright, I'll do that then.
Old Dec 2, 2013 | 04:03 PM
Twmays's Avatar
Twmays
Your local box store will usually have both in stock and cheap.
Wal-Mart, Best Buy, Radio Shack, even Advance and Auto Zone usually have install kits.
Old Dec 2, 2013 | 04:04 PM
97r/tram's Avatar
97r/tram
Walmart has them.
Old Dec 2, 2013 | 05:27 PM
The Griff's Avatar
The Griff
Well I tried the two radios that aren't in the half ton, in the Cummins, and interestingly enough, they don't work.
Old Dec 3, 2013 | 08:44 PM
The Griff's Avatar
The Griff
Ok, double post time.
I decided to try the radio that is currently in the truck, the original one, with a definitive yes, it works, or no, it doesn't.
I took a car battery and sat it on the floor of the truck, hooked the ground to the ground cable from the radio, and the positive to both the constant, and key on power.
What happened? Not a damn thing.
