2000 dodge ram hood release
Old Dec 3, 2013 | 06:13 PM
envirodiver's Avatar
envirodiver
Default 2000 dodge ram hood release
I pull the handle to release the hood on my 2000 ram 1500 pickup and the hood won't release. How do I get it open
Old Dec 3, 2013 | 07:32 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Dec 4, 2013 | 01:20 PM
Have someone else pull the release, and hold it, you push down on the hood first, and then try to lift it.
If that works, lube the latch really well. If it doesn't, you might be able to disassemble the release (inside the truck) and yank on the cable with a pair of pliers. (cable probably is stretched.)
Old Dec 4, 2013 | 03:20 PM
Sheriff420's Avatar
Sheriff420
If you get no where with the cable in the truck then it's only two bolts to take the catch bar thing off the hood from underneath. You will need 2-3 feet of socket extensions and I believe a 10mm socket. If you go that route then you should get a towel or a jacket to hold down on it when you release the latch, if you don't hold down on it when you release the latch then I hope you have a clean pair of underwear on hand.
