Clicking when 4 wheel drive is engaged
Old Dec 7, 2013 | 01:48 AM
studders's Avatar
studders
Default Clicking when 4 wheel drive is engaged
Hello to all, I know that there is probably threads out there about this topic already. I have a 1999 dodge ram 1500 4x4 5.9L. While driving in 2w it is fine. But when I engage the 4w, there is a clicking sound from underneath the truck. I cant tell if it is coming from the front of the truck or if it is coming from transfer case. When I have to turn slightly it seems like it gets louder as well. I changed the fluid about 2 1/2 years ago when I overhauled the transmission. So I know that it could be 1 of several things. Just looking for some obvious things to check on. I don't drive it much only a little bit on the weekends and if I have to pull something. Winter is upon me and I may need it soon. I probably should of started looking at this situation a long time ago instead of waiting for the last minute. lol.
Another thing is a few years ago I had to change the bearing inside the rear differential and Im pretty sure I got it geared back up right but who knows. I don't know if that would have anything to do with it since I did that a few years ago and the clicking really didn't start until about 8 or 9 months ago. Over the past 3 years I have replace both front u-joints and both front hub bearings. Not saying its not either one of those already again but that is all of the work that I have done with the front end. Any help would be greatly appreciate. Thank you
Old Dec 7, 2013 | 01:14 PM
Check u-joints in the front drive shaft, and the outer axles. The front joint on my front shaft was just about gone, and it made some rather interesting noises in 4x4.
Old Dec 7, 2013 | 02:28 PM
studders's Avatar
studders
I will check that probably tomorrow and give an update. Thanks
Old Dec 7, 2013 | 03:43 PM
studders's Avatar
studders
I just got done checking all the u-joints. The front drive shaft seem fine but the passenger side outer is worn out pretty bad. Its just weird because I just replaced both sides no more than 2 years ago or so. I used moog parts and had them pressed in by the fleet department where I work. Wouldn't I of heard some clicking from the front even without engaged in the 4 wheel? When they went out the last time I heard it pretty heavy. I haven't heard anything from the front until I put it in 4w. I guess I will get that done soon and see what happens. Thanks
