Been a while...warm-up/idle confussion
Old Dec 12, 2013 | 09:50 AM
Flue's Avatar
Flue
Default Been a while...warm-up/idle confussion
Haven't had many problems with the rust bucket, but then I don't drive it daily when there is no snow on the ground....now it's a daily driver.
Lately (starting a few months back) the truck has needed two cranking sessions to start. Used to start on about the 3rd turn over. Now I give it 4, stop and two more and it starts right up. If it's been running a bit it will backfire or 'feel' like the timing is off and then start and run just fine.
Next issue. On these -1 deg mornings, it will start like above, let it warm up and it will struggle and then die after the coolant warms up to around 140/150. As soon as I get above that point it runs fine. If I've started driving before this warm up range it will die when I stop.
Any thoughts? Choke?
Thanks.
Old Dec 12, 2013 | 11:05 AM
There is no choke.
Check fuel pressure first. See what that looks like. Sounds like the drain-back valve has failed..... You can replace just the regulator portion of the assembly, but, it is almost as much as replacing the whole thing...... which is actually a better idea.
I would also be tempted to yank the throttle body, and clean it thoroughly. Not sure if it is a contributor to your problem... but, it sure wouldn't hurt.
Have you fixed your plenum yet? Vacuum leak would also give you some odd symptoms.
Old Dec 12, 2013 | 03:28 PM
Flue's Avatar
Flue
Fixing the Plenum......is on my list.
Tromping through the woods, fields and streams and how renovations get in the way of auto-wanna's .
Thanks, I'll look into the drain back next couple of days.
Might explain why it starts right up once in a while, after a few hours of sitting. Come out to go to lunch one day and starts the first crank...next 5 days it won't.
Old Dec 12, 2013 | 03:37 PM
Flue's Avatar
Flue
Mr. HeyYou....would that also account for a drop in rpm when the clutch is depressed? Once things get warmed up, coming up to a stop and using the clutch will let the rpms 'bounce' below 600 it will stall.
