Chasing a Ghost?
Old Dec 14, 2013 | 05:25 PM
ngmillar's Avatar
ngmillar
Chances are, you won't be able to see it. If you can, the heads are toast..... If you can manage it, send them to a machine shop to be cleaned and checked. If they are bad..... replace them. Just smile nice at your mom.
Ha alright thanks for all the help.
Old Dec 14, 2013 | 06:17 PM
ngmillar's Avatar
ngmillar
Oh and if by any chance you even had a rough estimate of what it may cost me to take it into a machine shop that would be awesome
Old Dec 14, 2013 | 06:33 PM
Probably somewhere in the neighborhood of 75 to check them out.... then it just depends on what they need.
Old Dec 18, 2013 | 08:37 PM
ngmillar's Avatar
ngmillar
Hey man justed started to tear into the truck and the hose from my throttle body broke just wondering if you knew the name of it so I can replace it
Old Dec 19, 2013 | 12:23 AM
ngmillar's Avatar
ngmillar
I see its just a vacuum line now so I'll add that to what I have to do.
Old Dec 19, 2013 | 10:26 AM
Yep, no coolant makes its way as far as the throttle body. Just vacuum lines. The original plastic fellers love to dry out, and become very brittle, to the point that giving them a hard look will cause them to disintegrate.
Old Dec 19, 2013 | 02:21 PM
97r/tram's Avatar
97r/tram
OP, I have a set of heads that are crack free. (new casting off of a jasper longblock) Maybe 10k on them. I'm in georgia too.
Old Dec 21, 2013 | 09:29 AM
ngmillar's Avatar
ngmillar
Thanks man but I won't be needing them.
Old Dec 21, 2013 | 09:31 AM
ngmillar's Avatar
ngmillar
So I finally ended up getting it all apart and back together... now my only problem is getting these two bolts tightened down that gold the manifolds to the rest of the exhaust. Any tips on getting them back together?
Old Dec 21, 2013 | 10:35 AM
Are they just too far a way for the current bolts? Not lining up?
