How do I tell
Old Dec 16, 2013 | 02:20 AM
Ram Driver's Avatar
Ram Driver
Default How do I tell
If my 2000 Ram 1500 4x4 has a limited slip rear end ?.
Old Dec 16, 2013 | 02:38 AM
cmikolajczyk's Avatar
cmikolajczyk
Find the identification number on the axle and we can tell you for sure.
Old Dec 16, 2013 | 02:41 AM
Ram Driver's Avatar
Ram Driver
Am I looking for a tag or a number stamped on the axle some were ?.
Old Dec 16, 2013 | 02:53 AM
cmikolajczyk
Follow this link, it's explained here with pictures.
http://www.vibratesoftware.com/html_..._axle_tags.htm
Old Dec 16, 2013 | 08:54 AM
CSDavies26's Avatar
CSDavies26
OR you can email dodge and ask for your build sheet...that's what I did to figure out exactly what my truck's factory specs were. I believe there's a thread on that in the "how-to" section.
Old Dec 16, 2013 | 09:49 AM
cmikolajczyk
That's true, but only if it's still the factory axle.
Old Dec 16, 2013 | 11:13 PM
ReadRam's Avatar
ReadRam
Or do a little spin out in the snow or some loose gravel,then go back and look at your tracks, if it's open then only one tire will spinout , if limited slip both tires will grab and leave a double spin out patch.
Old Dec 16, 2013 | 11:19 PM
Thornloe Pride's Avatar
Thornloe Pride
Jack up the rear and spin one tire with your hand. If the other tire spins in the same direction, you have limited slip. If it doesn't, then you either don't have LS or it's shot.
