Engine bogging
Old Dec 17, 2013 | 07:44 PM
hawks.fan55's Avatar
hawks.fan55
Default Engine bogging
1998 5.2 v8 bogs when under 1k. Just replaced spark plugs, cap and plug wires, changing oil every 3k miles. I don't know if it could be the fuel pump/filter or any of the sensors
Old Dec 17, 2013 | 07:49 PM
TheBigRedTruck's Avatar
TheBigRedTruck
What's it like above 1k rpm?
Old Dec 17, 2013 | 07:52 PM
hawks.fan55
Runs fine, when you take off from a stop it chugs and pops. I don't think there is a vacuum leak anywhere.
Old Dec 17, 2013 | 07:54 PM
TheBigRedTruck
IAC valve may need to be replaced
Old Dec 17, 2013 | 07:55 PM
chromed95's Avatar
chromed95
welcome to DF.. plenum been fixed?
Old Dec 17, 2013 | 07:57 PM
hawks.fan55
Thanks chromed95, plenum has not been fixed yet. Did not think of the IAC valve. Ill check them and go from there. Thanks
Old Dec 17, 2013 | 07:59 PM
TheBigRedTruck
forgot about the plenum lol, do that first
Old Dec 17, 2013 | 10:15 PM
Thornloe Pride's Avatar
Thornloe Pride
Has the truck been in water/mud lately? Coil could have gotten wet. I've seen that cause a bog before.
Old Dec 18, 2013 | 12:17 PM
hawks.fan55
Has not been in mud/water, just through the snow. I don't think 8 inches of snow coulda caused it to bog, but I could be wrong
Old Dec 18, 2013 | 12:50 PM
Thornloe Pride
Naw you should be fine. Like previously said, take a look at plenum and clean the IAC sensor.
