95 1500 5.2 HELP Please
Old Dec 19, 2013 | 02:37 PM
dviper_2001's Avatar
dviper_2001
Exclamation 95 1500 5.2 HELP Please
Hi i've got a 95 1500 5.2 4x4 5spd manual
My problem happened on the interstate...I lost forward gears except for 4th and reverse still works... no noises or unusual sounds...
thanks to everyone
Old Dec 19, 2013 | 02:40 PM
Check fluid level first. (in neutral) If that looks ok, time to drop the pan, and see if there are any chunks in there.
Old Dec 19, 2013 | 02:43 PM
97r/tram's Avatar
97r/tram
Pan? On an nv3500
dviper_2001
fluids good...no shavings or chunks in case...
changed the clutch n pressure plate..didn't see anything
was told it was a nylon pin that holds the forks to the selector... nobody seems to know what or where it is
thanks tho
Old Dec 19, 2013 | 02:44 PM
Ooops. Missed the "manual trans" part.....
In that case, it is more than likely simply time for a replacement. Good time for an upgrade?
Welcome to DF!
Old Dec 19, 2013 | 02:51 PM
dviper_2001
Welcome to DF!
Thanks and Thank you for the quick response
