Help!! PO645 code A/C clutch relay circuit problem.
Old Dec 21, 2013 | 09:31 PM
Ramthis98's Avatar
Ramthis98
Default Help!! PO645 code A/C clutch relay circuit problem.
How to fix it,
Any idea why did this code come out? And is there anyway
I can get it fix,
Old Dec 22, 2013 | 11:26 AM
Try swapping the relays around, and see if that solves the issue. if not, go thru the wiring...... diagrams are in the service manual. (the 01 manual in the faq section should work for yours as well. wire colors might be different though.)
