At Wits End--Engine Loss of Power, Backfires
Old Dec 27, 2013 | 05:59 PM
  #21
ClubCab5.9's Avatar
ClubCab5.9
I be looking at the timing chain for slack even if its new. Can view the fuel sync at idle if its bouncing around alot its the chain. Cloyes, comp ect ect will develop slack in a very short time. Rollmaster or JP performance will not stretch and if ment for performance builds unlike the other chains being OE replacements. MSB have a taller deck height making the timing chain much longer.
Old Dec 27, 2013 | 10:31 PM
  #22
Spdracer37's Avatar
Spdracer37
Picked up my truck today. Shop told me they reset my fuel sync to 0, checked fuel pressure and volume(39psi) on initial startup and driving. Drove the truck home with no issues so far, still acts like it is low on power a smig.
I have a double chain setup, cant remember brand name, also new 24 psi injectors with the upgraded tips for more spray. Im checking my ground wires, have 2 that run to block, tomorrow after work. Will keep u posted redneck.
Old Dec 30, 2013 | 08:32 AM
  #23
Moparman59's Avatar
Moparman59
Thumbs up Tensioner
Sounds like truck is running better with full sync adjustment. Eventually all timing chains develop slack from wear. I just had a MP timing chain tensioner installed at my build time. Cheap insurance. If it is an issue install a decent chain with the MP P5007709 tensioner.
Old Dec 30, 2013 | 09:26 AM
  #24
redneck_ram's Avatar
redneck_ram
Any updates spdracer?
Old Dec 31, 2013 | 12:26 AM
  #25
army_greywolf's Avatar
army_greywolf
That'll do it, but you'll lose bottom end as the chain stretches no matter what right? Or do I have that backwards...hmm.
Old Jan 1, 2014 | 10:49 AM
  #26
Spdracer37's Avatar
Spdracer37
Update= Trucks been running ok for almost a week now. I think I have a stuck open thermostat atm, truck wont get any hotter than 145 degrees. I had found a ground strap that runs from the firewall to the intake, not attached. The only two repairs that were done were, setting fuel sync and reattaching a ground. Hope this helps redneck.
Old Jan 1, 2014 | 10:52 AM
  #27
Yeah, replace the thermostat. I know I want all the heat my engine can put out this time of year..... Tis COLD out there.... and snowing.
Old Jan 16, 2014 | 07:57 AM
  #28
redneck_ram
Wanted to bump this thread. Hows the truck running spdracer?
