Heat
Old Dec 25, 2013 | 12:08 PM
Weemet's Avatar
Weemet
Default Heat
I only get heat in the cab when the revs are high
The engine takes a long time to heat up
I have put in a winter thermostat and did a heater core flush
Old Dec 25, 2013 | 12:40 PM
What's a winter thermostat? Stock is 195 degree.
You show all the signs of being low on coolant, and a failed thermostat.
Old Dec 25, 2013 | 10:59 PM
Weemet's Avatar
Weemet
New thermostat was put in and I am not low on coolant
Old Dec 26, 2013 | 08:42 AM
redneck_ram's Avatar
redneck_ram
new thermostats can fail. seen it happen. just be glad it didnt get stuck closed!
Old Dec 26, 2013 | 10:05 AM
Does your engine get up to temp? How long does it take?
If everything else is as it should be, there is more than likely a blockage, or air bubble in the system. Heater core is notorious for trapping air..... (being as it's the highest point in the cooling system.......)
Old Dec 30, 2013 | 03:07 PM
Rodo1994's Avatar
Rodo1994
If my heater core is leaking when I put the heat to the floor fans, can I flush the heater core lines? Or do I HAVE to replace my whole heater core? ---Heat gets warm after truck has been warm, but then goes to luke warm air sometimes.
Old Dec 30, 2013 | 03:53 PM
ChillyPhil's Avatar
ChillyPhil
Unclamp your two heater lines and spray water through them first. See if that helps out any.
I did that and switched from my 180* tstat to a 195* for winter and it helped some. Still don't have HOT heat.
Old Dec 30, 2013 | 06:08 PM
Rodo1994's Avatar
Rodo1994
Which lines would I be running water through Both the left and right.?
Old Dec 30, 2013 | 08:16 PM
If your heater core is leaking, you need to replace it.
Old Dec 31, 2013 | 02:03 AM
Rodo1994's Avatar
Rodo1994
It's not leaking anymore, only the short period of time when I got it back from the dealership (had a diagnosis for my motor) but noticing a bird chirping like sound in the dash. Alway been there just never though of anything until I read about "that" sound.
