motor stumble
Old Dec 27, 2013 | 08:52 PM
Tyler Springhetti's Avatar
Tyler Springhetti
Default motor stumble
My 2001 dodge ram 1500 4x4 has the 5.9 liter motor. I get a stumble in the motor when and only when it is at half temp. I have to drive the truck from cold to normal temp it runs fine. I leave it for a half hour, then start it to go and I get the stumble. In drive and or in reverse. This is the only situation when it happens.
The motor has a new distributor, new coil,plugs,wires,temp sensor. I have cleaned the MAF. The fuel pressure has checked out fine also. The dealer said they pro formed a smoke test to eliminate the plenum gasket as a problem. they said it passed. The truck runs great all the time except in this situation. I was looking for any suggestions on what i might do to try to remedy the problem. Any suggestions would be appreciated.
Old Dec 28, 2013 | 09:36 AM
Does it just miss a bit? Hesitate when you step on the gas?
Old Dec 28, 2013 | 03:28 PM
Tyler Springhetti
yes, only when you step on gas.When it happens,I let off the gas, then step on it slowly again and it runs normal.
Old Dec 28, 2013 | 03:35 PM
check the throttle position sensor. Sounds like it might have a dead spot.
Old Dec 29, 2013 | 05:47 PM
Tyler Springhetti
I checked out the tps with a volt meter test. It is only 5 months old. It tested out ok. Any other suggestions. Thanks
Old Dec 30, 2013 | 11:06 AM
Digital or analog meter? Digitals don't react fast enough to give an accurate test.
