still no power
Old Jan 3, 2014 | 06:43 PM
dieselsuburban95's Avatar
dieselsuburban95
Default still no power
I got my truck all back together new timeing chain new plenum plugs copper cap rotor and it still acts like its draging something any suggestions
Old Jan 3, 2014 | 07:07 PM
merc225hp's Avatar
merc225hp
Was a comp test done? What where the numbers? Post them if you have them. If one was not done now is the time.
Old Jan 3, 2014 | 07:21 PM
dieselsuburban95
No I haven't done one
Old Jan 3, 2014 | 07:40 PM
merc225hp's Avatar
merc225hp
Well no time like the present is there, cover the basics first. Please do a comp test or a leakdown test. Lets make sure all your work/time and money was not wasted.
Old Jan 3, 2014 | 08:44 PM
How is your catalytic converter? Plugged up from the blown plenum? That will most certainly reduce power output....
Old Jan 3, 2014 | 08:46 PM
dieselsuburban95
No its hollow all the plugs look good so I dont think I have a compression problem
Old Jan 3, 2014 | 08:52 PM
Plugs won't show a compression problem. Need to actually run the test.
Does it run ok when cold?
Old Jan 3, 2014 | 09:00 PM
dieselsuburban95
It runs great all the time it used to idol rough but I cleaned the iac and throdle body now it ldols good
Old Jan 3, 2014 | 09:01 PM
What size tires, and what gears ya got? I assume auto trans?
Old Jan 3, 2014 | 09:09 PM
dieselsuburban95
Yea its auto 265 70 17 and stock gears I guess nothing else had been done so I figure they havent eather
