46re, 3 codes, 99 2500
Old Jan 9, 2014 | 09:19 PM
aaron1999's Avatar
aaron1999
Default 46re, 3 codes, 99 2500
is onP0740 torque conv clutch, no rpm drop@ lockup
P0500 no vehicle speed sens signal
P0713 trans temp sens voltage too high
Speedo not working, abs/brake light is on and tach is irratic.
any help on one or all would be nice. Thank you
Old Jan 9, 2014 | 09:37 PM
P0740 comes up a fair bit, but, doesn't necessarily indicate a failure. Fix the others, clear the codes, and see if it comes back.
Speedo, ABS lite, Brake lite: Replace the speed sensor on top of the rear diff.
Trans temp, check the connector on the trans. (drivers side, 'bout halfway back, 8 pin connector) Make sure it is clean, tight, and there are no exposed wires.
Let us know what ya find.
Welcome to DF!
Old Jan 9, 2014 | 11:31 PM
aaron1999's Avatar
aaron1999
Thank you HeyYou, I'm going to call to get that new sensor in the morning. And check that plug.Will update post tomorrow.
Old Jan 24, 2014 | 02:20 AM
aaron1999's Avatar
aaron1999
OK sorry it took so long to post reply, changed out the send listed above, no codes no problems. My brake light is still on but I believe that is due to another issue
