oil pressure problem
Priming the oil pump is different than priming the engine. Merc's post is for the pump.
To prime the engine the distributor and intermediate shaft is pulled. Then a priming shaft is attached to a drill and inserted in the pump to turn the pump rotor in the direction of the firing order.
