low idle in gear
Subscribe
Jan 12, 2014 | 04:27 PM
Ok cleaned iav no help replace still low idle in gaer drops to below 500 rpm mark on dash
Reply 0
Jan 12, 2014 | 04:35 PM
Reset the PCM. (disconnect the battery, turn on headlights, count to ten, turn off headlights, hook battery back up.)
Reply 0
Jan 12, 2014 | 04:42 PM
Disconnected battery same idles just above 500 in park put in gear drops below 500
Reply 0
Jan 12, 2014 | 05:21 PM
is it idling smooth?
Reply 0
Jan 12, 2014 | 06:24 PM
Has very little wobbly idle
Reply 0
Jan 12, 2014 | 06:49 PM
Does it smooth out if you give it a little gas? Or does it continue to run rough?
Reply 0
Jan 12, 2014 | 06:57 PM
Seems to have a little wobble at times seting a po138 code idle is a smooth up down not realy a rough idle hardly see it on tach meter just reaby about500 slightly higher in park
Reply 0
Jan 12, 2014 | 07:06 PM
Can you test the throttle position sensor?
Reply 0
Jan 12, 2014 | 07:13 PM
How can you test tps
Reply 0
Jan 12, 2014 | 07:53 PM
Analog multimeter.
Reply 0
