Short Block
Old Jan 13, 2014 | 11:24 AM
southpaw1249's Avatar
southpaw1249
Default Short Block
I am thinking that i will be throwing a new engine in my truck sometime when the weather gets warmer.
My main question is where can I get a short block 318 to replace my current motor?
Old Jan 13, 2014 | 11:55 AM
Short block doesn't come with heads. The one part on these motors that REALLY needs replaced on a rebuild.
many places offer them though, including your local parts stores.
Old Jan 13, 2014 | 12:00 PM
southpaw1249
well i have terrible compression numbers on my motor so i figured i should replace the bottom end as well.
Old Jan 13, 2014 | 12:03 PM
Pick up a long block, (comes with heads) or, yank yours, rebuild it, and replace the heads. (actually a better option, as 99% of rebuilds come with reman heads, which still have the same weaknesses as the factory fellers.... as they started out life that way.) or, pick up a rebuildable core, rebuild that, and then just swap motors. That way, while the rebuild is going on, you can still drive the truck.
may wanna do a cylinder leakdown test, and see just where your problems are. combine that with a dry/wet compression test, and it gives you a really good idea of just where the major problems are.
Old Jan 13, 2014 | 12:11 PM
southpaw1249
Is there a good place to pickup a rebuildable core?
Old Jan 13, 2014 | 12:57 PM
Junkyard, craigslist, local classified ads, etc.
I seem to have a spare 360 I am not going to use......
