Modified V10 Intake Manifold
Old Jan 15, 2014 | 10:45 AM
BlackRam1010's Avatar
BlackRam1010
Default Modified V10 Intake Manifold
Hello,,Has anyone done any type modification to a V10 intake manifold,,I have heard some improvements can be made to it,,would love to hear of them,,Thanks to all that may chime in on this
Old Jan 15, 2014 | 11:41 AM
Could do some port matching, that sure wouldn't hurt.... of course, that would require yanking the heads to do a complete job.....
Old Jan 15, 2014 | 12:03 PM
JTB488's Avatar
JTB488
This spring when I plan on fixing the valve cover gasket leak am curious about sending the manifold out to get extrude honed.If it's even worth it though...??
Old Jan 15, 2014 | 12:08 PM
BlackRam1010
could you explain what that type of honing will do to the manifold,,and what kind of cost will this be??thanks
Old Jan 15, 2014 | 12:19 PM
JTB488's Avatar
JTB488
It's basically a abrasive putty that is forced under pressure thru what ever and cleans/deburrs/smooths . It can reach every nook.
Old Jan 15, 2014 | 12:26 PM
I could see how extrude honing could indeed give you better performance. Not like you need turbulence in the runners to keep the fuel in suspension.... (as there is no fuel in the runners....) Combine that with some porting/port matching, and you could prolly pick up a few ponies.
Would it be noticeable in and of itself? Doubt it, but, it would most certainly help any other mods you do work better. Combine doing that with a good, free-flowing exhaust system, and I would expect THAT would be noticeable.
Trouble is, there isn't much of a market for aftermarket performance parts for the 8.0 any more.......
Old Jan 15, 2014 | 12:30 PM
BlackRam1010
Thanks for the info on honing,,Does anyone know where something like this could be done,I have a spare intake that I could send out
Old Jan 15, 2014 | 12:31 PM
have to check around your area. Not everyone does it.... but, if there is a local machine shop, and they don't do it, chances are good, they will know someone that does.
Old Jan 15, 2014 | 12:33 PM
BlackRam1010
sounds great,,I will look into this!!
Old Jan 15, 2014 | 12:36 PM
JTB488's Avatar
JTB488
I already picked up a Fastman throttle body and installed it. Have the Mopar Performance PCM and a set of headers waiting to go on once we are out of winter.
