Running light fuse keeps blowing
OK so my running light fuse 15amp u dear the hood keeps blowing.. It blows 80%of the time immediately after sticking a new one In... It is not blowing with running lights off but as soon as I turn them on it blows.. Now I do have an aftermarket stereo an a system, halo projector headlights an aftermarket taillights.. Any ideas??
My running light fuse kept blowing in my 2001 Durango when I had a ground in the trailer light wires. Caught up on my exhaust and melted right through the insulator it had on it, plus the wire insulation.
Pull it and have a look. If the connector is all melted, you found at least one problem. If everything looks ok there.... well, need to keep looking.
Yep connector was fine this all started happening after I had the stereo turned up loud with the truck not running then the check gages light came on an it showed no battery voltage an it's been blowing fuses ever since
Trending Topics
Ok, that's the way it is supposed to work. (it should 'test' when you first start the truck.... but then, stay off, unless there is a problem.)
Got a trailer harness on that truck? If so, try removing it from the circuit. (should be able to just unplug it.)
