Electrical issues
Old Jan 19, 2014 | 12:38 AM
dokeefe0915's Avatar
dokeefe0915
Unhappy Electrical issues
Alright I'm probably doing this wrong so please forgive me. I have a 99 2500 with the 360. The truck has been a gem since I bought it a couple months ago. Last week I noticed that my glove box light did not work so I tried replacing the bulb with no luck. So I put a multi meter on it and my map, radio, convience, ignition ring, third brake light and still glove box all went out. All fuses are good. The head lights and parking lights all work. The truck starts and drives like normal. Now the CEL is on. My scanner cant read the truck. I need an adapter. Anyone have any ideas or direction I could go in?
Old Jan 19, 2014 | 12:30 PM
xjarhead69's Avatar
xjarhead69
IF you have no burnt fuse's try replacing the lights that burnt out, other than the glove box and see if they will work again.
I suspect the IOD fuse is blown.
Dave
Old Jan 19, 2014 | 04:16 PM
dokeefe0915
Alright it was the IOD fuse that blew. Thank you for that. I didn't have a full understanding of the impact that fuse had. So now my lights work. Minus the glove box light. That is the only light in my truck that doesn't work. All fuses are good. Any place the wires pinch behind the dash board? The bulb is new also. The under hood light does work if that helps give anyone some direction.
Old Jan 19, 2014 | 04:38 PM
ryan0714's Avatar
ryan0714
u can lower the glove box down more, open it, and pry the back wall of it down so the latches clear and the whole box will drop down, then u can see the connections behind it. could just be a wire got pulled out of the harness connection.
Old Jan 19, 2014 | 07:57 PM
xjarhead69's Avatar
xjarhead69
I would try what ryan say's here and work your way back to the fuse box.
Check all wire and connections and make sure the button that pushes in on the switch is actually moving.
The switch may just be bad.
Dave
Old Jan 20, 2014 | 08:53 PM
dokeefe0915
Quick update. I pulled most of the dash apart today and traced the wires as best I could. Everything seems to be connected properly. I did find out that I also have a cup holder light. Its in the back of the drop down cup holders. That bulb is also good but does not seem to work. Any known connection between the two?
Old Jan 20, 2014 | 10:48 PM
xjarhead69's Avatar
xjarhead69
According to the 2001 manual they have a common ground.
Start checking grounds.
Does your cigarette lighter work?
Dave
Old Jan 20, 2014 | 11:19 PM
dokeefe0915
Both my cigarette lighter and my power outlet work no prob.
