Pulls to the left?
Old Jan 22, 2014 | 10:52 AM
KxRideRon125's Avatar
KxRideRon125
Default Pulls to the left?
Truck keeps pulling to left., faster jI go harder it pulls replaced my rubber brake line hoses to see if that would help an iit's been aligned multiple times, when I hit the brakes sometimes it pulls to the left, an sometimes it will drive if everyone for a couple of miles than start pulling agian any ideas
Old Jan 22, 2014 | 10:58 AM
Ham Bone's Avatar
Ham Bone
sounds like a sticking caliper....
Have you inspected your steering linkage yet?
Old Jan 22, 2014 | 11:07 AM
Annihilator_X9's Avatar
Annihilator_X9
I would say it's the caliper also. Check the pins and see if they're seized up. I had one on my Mustang that wouldn't hardly budged so I got a brake hardware kit and some grease to replace the pin and free it up. If that doesn't work then the caliper would need to be replaced if it is indeed a brake issue.
Old Jan 22, 2014 | 11:52 AM
KxRideRon125
All front end parts are tight and mostly new, I got a brake hardware kit an installed it an it seemed to work for bout a day if that
Old Jan 22, 2014 | 02:53 PM
merc225hp's Avatar
merc225hp
I was having a lot of problems with my calipers not floating on the pins (Dana 44), clean them grease them and in less than a week they would be seized solid again. So after talking to my parts guys about this they recommended this product, Permatex Ultra Slick Ceramic Extreme Brake Lubricant after going to this product all my caliper floating problems stopped. I now use it religiously when rebuilding brakes.
Old Jan 22, 2014 | 04:13 PM
Annihilator_X9
Wonder if the caliper is getting hot and cooking the grease.
Old Jan 22, 2014 | 04:35 PM
merc225hp's Avatar
merc225hp
^^^+1 Yep thats why I was told to go to the ceramic grease.
Old Jan 22, 2014 | 04:40 PM
KxRideRon125
Might be bc I've only used grease from a grease gun, but would that still cause it to pull to the left when applying the brakes
Old Jan 22, 2014 | 05:05 PM
merc225hp's Avatar
merc225hp
If the pins are seized yes it will. Take apart the pins, clean everything with brake cleaner then at least use some type of brake grease on them. Reg grease will not work at all nor will anti-seize compound.
Old Feb 7, 2014 | 10:17 AM
KxRideRon125
i replaced the calipers an got all new hardware with them, used that grease you told me about an still faster i go harder it pulls to left
