Low speed E-fan
Old Jan 23, 2014 | 04:17 PM
MedicNathan's Avatar
MedicNathan
Default Low speed E-fan
Hey guys, Last fall I installed the efan set up from TCP. The thing is wonderful
On the down side the two hi speed fans from SPAL are beyond overkill, which makes running my defroster a bitch in the winter. Anyone have a recomendation for a good low speed fan?
Old Jan 23, 2014 | 04:55 PM
Why are the fans running at all when it is that cold out?
Do those fans support multiple speeds? Two-speed fan controller wouldn't hurt.....
Old Jan 23, 2014 | 08:20 PM
Spillage's Avatar
Spillage
SPAL fans are a single speed fan, but work with SPAL (if you can find one) or Flex-a-lite variable speed controllers... these ramp up the speed of both fans (wired together) to a low setting of ~60%, and then increase the speed if adequate cooling is not achieved... A/C override brings them on at 60%.
Derale has a dual fan controller... it starts with fan#1 at 100%, and kicks in fan#2 if fan#1 isn't doing the job... A/C override kicks in fan#1.
My guess on fan activity in the cold, is the A/C cutting in to control cabin humidity... remember, water is always flowing through the heater core, and the blend door mixes the hot and cold to the selected temp.
Old Jan 28, 2014 | 01:27 PM
MedicNathan
I have the derale controller. and yes the fans are kicking on due to ac override when the compressor kicks on for the defroster.
I was hoping to not have to replace the controller as I am actually really happy with it, there is also the cost of a new one. I've had it idle at 95* outside and never had more than fan #1 kick in. Its such a huge energy draw at idle though, the electrical system just can't keep up. Especially in winter.
a variable speed controller shouldn't harm the single speed fans should it?
Old Jan 28, 2014 | 01:33 PM
Don't know.
The other alternative would be to upgrade the alternator. Might be cheaper... certainly be easier. Its a direct bolt on. Consult your build sheet, and see what amp output alt came stock. Take it from there. I have seen 220 amp alts for our trucks. (granted, they were expensive.....)
Old Jan 29, 2014 | 10:42 AM
MedicNathan
Wait, does that mean you have found cheap parts for our trucks in the past?! What is your secret master!!!
Old Jan 29, 2014 | 11:04 AM
Craigslist, EBay, Discount codes, Neighbors.
Yeah, basically, it boils down to one word. "Luck".
Also, I have a bit of an advantage. I have been 'in the business' for a couple decades, and have pretty much used the same suppliers the whole time, so, they know me on a first name basis, and I get some pretty good discounts on parts.
