1997 Ram 5.9 mid throttle no load misfires
Engine starts and idles fine. When driving in a no load speed it misses badly. Same when shifting gears. Otherwise it accelerates smoothly with lots of power.
Have replaced plugs ,wires, rotor ,cap, coil, and re-routed wires as per TSB 18-48-98
Where should I look next?
Cleaned and tested TPS checks ok, So checked for codes and Crank Sensor comes up, Order a new one and install.
Runs great for about 10 minutes then sputters and loses power but still runs barely at any speed or revs.
Checked for codes and got Camshaft code. Not sure want to spend more as something weird seems to be happening.
Forgot to mention before that installed new fuel pump too.
Any more ideas?
Any more ideas?
