towing
Old Feb 3, 2014 | 12:47 AM
studders's Avatar
studders
Default towing
Hello to all. Just have a question because I'm kind of curious. I bought a boat over the summer. I have noticed that on my way home from the lake I have to go up the same hill every time. It really isn't to steep of hill but it is long about 2 miles maybe a little less. My boat only weighs about 2300-2400 lbs. I almost have to get a good start to even make it up the hill. I get about half way up and I have to floor the gas pedal but I do not gain any speed. In fact even with the pedal all the way to the floor I start to lose speed. It is a 2 lane road so I can get all the way over to the right. I checked the throttle cable to see maybe if it was stretched but it is not. It has a new catalytic convertor on it and I do regular oil changes and tune ups when it is due. I myself do not think that this is normal but I am just asking for everyone else opinion. I appreciate it and thank you.
1999 Dodge Ram 1500
4x4 5.9L
143,000 miles
Old Feb 3, 2014 | 12:52 AM
Ham Bone's Avatar
Ham Bone
It should downshift in passing gear. Does it downshift?
Don't ever tow with O/D on
Check TV Cable adjustment
Old Feb 3, 2014 | 09:15 AM
studders's Avatar
studders
I never really payed too much attention about it downshifting. I have replaced the transmission about 3 years ago. I'll keep that in mind about towing not towing in O/D. I have to confess that I rarely ever turn the O/D off except if maybe going just down the street. I will also check the tv cable adjustment. Bare with me if I don't update to soon, probably not until this weekend. I only drive my truck on the weekends and I work 2nd shift+ a lot of hours. Thanks for the input.
Old Feb 3, 2014 | 09:20 AM
Fixed the plenum yet? How recent is the new cat?
Old Feb 3, 2014 | 10:32 AM
studders's Avatar
studders
No I haven't changed the plenum gasket and the cat is only about 2 1/2 months old
Old Feb 3, 2014 | 10:33 AM
Ham Bone's Avatar
Ham Bone
I would add checking the plenum this weekend onto your list. It's quick and easy. Take the airhat off, 4 bolts from the throttle body and it's out of the way.
If you see oil pooling you need to fix your plenum.
Old Feb 3, 2014 | 01:10 PM
Annihilator_X9's Avatar
Annihilator_X9
Definitely check the plenum. If the gasket is blown you're leaking vacuum like crazy which will also cause power loss. My boat and trailer are a tad over 5,000lbs and my 5.2 tows it pretty good.
Old Feb 3, 2014 | 01:13 PM
studders's Avatar
studders
Thanks for all the input. I will definitely check the plenum this weekend and follow up.
Old Feb 3, 2014 | 01:18 PM
Arde's Avatar
Arde
+2 on checking the plenum....Leaking plenum gasket is most likely the reason for needing a new cat. in the first place. If not fixed, you'll be needing another new one very prematurely.
Old Feb 3, 2014 | 02:31 PM
Johnn123's Avatar
Johnn123
Don't tow in O/D ever unless you want to fry your trans.... Says it right in the owners manual lol.
Agreed with others most likely leaking plenum.
