Transmission problems
Old Feb 16, 2014 | 10:31 PM
crazy4x4468's Avatar
crazy4x4468
I downloaded the manual and and i just simply can not find that 8 pin connector on the transmission, i have to be over looking it,ive found the speed sensor connecter and the neutral safety connecector, then theres both 02 sensor connectors, the only other wiring under there is a couple larger connectors that appear to be capped off with connectors without wires, and they are laying on top of the trans.
Old Feb 16, 2014 | 10:34 PM
crazy4x4468
Meaning ive found it in the manual but i cant find it on my actual transmission
Old Feb 16, 2014 | 10:44 PM
xjarhead69's Avatar
xjarhead69
In this picture its above the nuetral safety switch to the right.
Dave
Old Feb 16, 2014 | 10:53 PM
crazy4x4468
Dave
Oh okay, thank you!
Old Feb 16, 2014 | 11:02 PM
crazy4x4468
So it turns out that has been unpluged this whole time and where it plugs into is covered in grease so i couldnt see it, all the wires are missing insulation for about half an inch before they go into the connecter
Old Feb 17, 2014 | 12:43 AM
merc225hp's Avatar
merc225hp
What year fuel pump are you using the 94 or the 97? 94 is 39 psi 97 is 49 psi.
Old Feb 17, 2014 | 08:51 AM
xjarhead69's Avatar
xjarhead69
Here is the replacement connector http://www.cascadetransmissionparts....essrepair.aspx
Free shipping too!!!
Dave
Old Feb 17, 2014 | 11:40 PM
crazy4x4468
Im using the 1997 fuel pump that came with the v10
Old Feb 17, 2014 | 11:43 PM
crazy4x4468
Dave
Thanks!
