97 Dodge Ram 1500 Shift Issues - Auto Tranny
Old Feb 5, 2014 | 07:27 AM
Kawlyn's Avatar
Kawlyn
Default 97 Dodge Ram 1500 Shift Issues - Auto Tranny
I know there are some threads which may have the issue. If so please point me in the correct area. And thank you in advance.
However, I am going to describe it in the best possible way.
Reverse gear works fine - no issues that I can see at all.
When put in drive I have to slightly accelerate and it gets up to 2,000 rpm.
I have to keep it there until around 35-40 mph, when it will move to second.
It will still sit around 2,250 rpm. Then it will get to third and then around 45-50 it will hit 3rd and drop to like 1,250 - 1,500 rpm.
I can throw the shifter into 1st and 2nd and it will respond well - just as 1st and 2nd should when it is in drive.
I would love to work on this issue myself. But if it is out of my expertise or time constraints, I would still love to walk into the shop with some ammo so they dont tool me around.
Any advice would be great. Thank you.
Old Feb 5, 2014 | 10:23 AM
First thing to try would be changing fluid/filter, and adjusting the bands. Procedure is listed in the service manual, which you can download for free from the service manual thread in the faq section. (don't think we have a 97 version, but, the 96 version will be damn close.)
Old Feb 5, 2014 | 11:07 AM
Arde's Avatar
Arde
Check the TV cable, adjust if necessary, sounds a little loose.
