Fuel Gauge
Old Feb 5, 2014 | 03:44 PM
mcpotex's Avatar
mcpotex
Default Fuel Gauge
Hello there. I'm new to the forum and I need some opinions.
I own a 1996 Ram 2500 5.9L Cummins Diesel. The Fuel Gauge warning light has been continuously illuminated for a long time. Rather than getting it fixed immediately I have simply been resetting the trip meter to zero after every fill-up. My questions are: Is this most likely a sending unit problem? If so, which is the better approach to repairing or replacing it...drop the tank or pull the bed? How much should I expect to pay for the work?
Thanks in advance for your help.
Old Feb 5, 2014 | 05:09 PM
You can unplug the connector at the tank, and put a jumper wire between the two pins for the gauge, and see if it moves. If it does, then the sender in the tank is toast.
Old Feb 6, 2014 | 09:41 AM
CSDavies26's Avatar
CSDavies26
I've done my fuel pump twice now (made the mistake of putting an airtex in the first time so I changed it last weekend for peace of mind)...my opinion is it's definitely easier to raise the bed. I've tried it both ways and those quick disconnect fittings are just a pain in the *** to try to get loose when reaching up from underneath the tank. I just pull the six bed bolts, unplug the tail lights and license plate lights, and have my dad or someone help me lift the bed up. I put a moving pad on the bumper and rest one corner of the bed there and the other corner on the rear tire. Much easier than dealing with that big bulky tank I think!
