Shifting when Cold
Old Feb 6, 2014 | 09:41 AM
brettclark624's Avatar
brettclark624
Default Shifting when Cold
I have a 1999 Dodge Ram 1500 with a 360. When it is extremely cold it doesn't shift out of 1st, but after I let it sit for 15 mins with the engine shut off then it shifts just fine. If anyone has any solutions to this problem, I would greatly appreciate it.
Old Feb 7, 2014 | 12:39 AM
jasonw's Avatar
jasonw
Site Moderator
3rd and final warning. Please post in the correct sections, you have been warned about this twice before. I will move you one more time. Not trying to be a jerk here, but when we tell you where to post twice, and you still post in the wrong place, it is a little frustrating.
If you are still confused about where to post, please see the below thread.
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Feb 7, 2014 | 01:02 AM
ReadRam's Avatar
ReadRam
Check that fluid level is correct..in neutral at operating temperature. Take a look at throttle lever on drivers side of transmission, there is spring to pull the the throttle valve cable back. The TV cable can stretch or the lever can get sticky, messing with 1-2-3 shift points. Somewhere to start.
