Hughes Throttle Body issues
Old Feb 7, 2014 | 11:25 AM
Hurtin_Albertan_Ram's Avatar
Hurtin_Albertan_Ram
Default Hughes Throttle Body issues
Hey ya'll, new member to the forum here, though I have read many old threads to learn as much as possible about my truck. But one thing I havn't been able to find is someone swapping a 1998 throttle body on a 1995 dodge, sounds stupid I know but hear me out lol. so I ordered a stage 1, type 2 (1994-19950 throttle body from hughes engines, but they sent me a type 3 (1996-2001) throttle body and accelerator cable to go with it. the install was easy but with the new throttle body my truck idle is way to high (1000-1300 rpm). I called hughes and they said it has to be a vaccum leak, I checked and there isn't one, could it be a computer issue? any help greatly appreciated, truck has a 5.9l magnum, idle was fine before throttle body swap, used old MAP, IAC and TPS sensor
Old Feb 7, 2014 | 12:13 PM
Reset the PCM before you do anything else. Just disconnect the battery, turn on the headlights for about 30 seconds, turn off headlights, reconnect battery.
Turn key to "On" (not start), count to ten, THEN start the engine. See if it idles any lower.
Also, make sure the throttle cable isn't holding the blades open.
Old Feb 7, 2014 | 02:31 PM
Hurtin_Albertan_Ram
I did disconnect the battery during the install, but never waited 10 seconds before starting the truck ill try that thank you, would the throttle body sensors be different between all the years of the 2nd gen rams? its a shame about the idle minus that the truck goes like hell now haha.
Old Feb 7, 2014 | 02:58 PM
Its my understanding that there are some differences, but, I wouldn't be able to tell you what they are.......
That procedure may, or may not help.... give it a shot, see what happens. Let us know.
Old Feb 7, 2014 | 07:56 PM
Hurtin_Albertan_Ram
Gave it a shot and no go, all good though I'm gonna experiment with the old throttle body and old sensors and the new tv and sensors, see which combo makes it go away and roll with it haha thanks for your help
Old Feb 7, 2014 | 07:59 PM
Hurtin_Albertan_Ram
Ment to write TB instead of TV my bad
Old Feb 7, 2014 | 08:18 PM
Please let us know what you figure out.
