Transmission slipping
Old Feb 9, 2014 | 11:34 AM
vc1's Avatar
vc1
Default Transmission slipping
The trans is 60k miles old on a rebuilt 48re. It's run strong for this whole time. All of the sudden it has trouble taking off from a stop when hot. Once I get it up to about 20mph it runs and shifts fine. I changed the fluid, filter and adjusted the tension on the outside adjustment. No change. Anybody have any suggestions?
Old Feb 11, 2014 | 10:30 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. What is the year of your truck? If its a 48RE, it'll have to be a 2500 or bigger, and a diesel or V10.
Moving you to the correct section. For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Feb 11, 2014 | 11:08 PM
Did you check fluid level in neutral? Engine fully warm, and running? (in neutral is important.)
Old Feb 12, 2014 | 09:32 PM
vc1's Avatar
vc1
Default Out of town for a few
The truck is a 3500 dually with a cummins in it. Yes I checked the fluid as well as changed it. no difference.
Old Feb 12, 2014 | 09:33 PM
vc1's Avatar
vc1
Oh and it's a 2004 with 220000 miles. Runs great! except for the tranny.
Old Feb 12, 2014 | 09:34 PM
stewie01's Avatar
stewie01
Could check the TV Cable:
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Could also do a band adjustment, see what that gets you.
A rebuild could be in your future though.
