46rh atf quantity and tv cable
Old Feb 10, 2014 | 11:58 AM
Rescue35's Avatar
Rescue35
Default 46rh atf quantity and tv cable
I droped the pan on my tranny and pulled the valvebody yesterday. How many quarts of atf +4 should it take to refill? I know the fsm calls for 2 qts after a filter change but it took me 5 before I had a reading on the stick but after 6 I have fluid all the way up above the z bend in the stick...I hope it is just residual fluid in the tube.
I also need a new tv cable as mine is frayed. On the up side the truck seems to be driving and shifting good.
Old Feb 10, 2014 | 12:03 PM
4 is usual, 5 has been seen, even 6, if it stays open for a while. You ARE checking the fluid in neutral, with the engine running, right?
Old Feb 10, 2014 | 12:29 PM
Arde's Avatar
Arde
It took mine almost 7 quarts after pulling the valve body. Check valve had been deleted which probably made a difference as well.
Old Feb 10, 2014 | 12:58 PM
Rescue35's Avatar
Rescue35
Yes, running in neutral. I also have an aux cooler and the check valve has been deleted. I'll drive it for a few minutes and then recheck. I just wish it was warmer...I live in the south for a reason. Thanks for the quick replies.
Old Feb 10, 2014 | 02:01 PM
Not south enough?
Old Feb 10, 2014 | 05:12 PM
xjarhead69's Avatar
xjarhead69
Not south enough?
Bermuda sounds good!!!
Dave
