Flexplate Question
Confirmed. Wrong converter in more ways than 1. Should have been the #6v with both bolt patterns. Got a #6d for a pre 96. They're checking the build sheet now.
Update: Correct converter being built. Will be shipped overnight. Due in Thursday, Friday at the latest.
i have a 97 ram 1500 the crank is now a 2 piece crank so i baught a 94 5.2 out of a ram 1500 4x4 that was totaled .my question is are the 94 and 97 flex plates the same can or should the bottom end be balanced with out the flex plate .i think the bolt holes are different but i am not sure any help would be greatly appreciated i have the 46 tranny
Learned something new today. Torque converters with the 90 degree bolt pattern have a 90 or a 0 with a line through it that identifies them. The models that do not have the 90 degree bolt pattern simply have a 0 or at O with an x in the middle. The converter I pulled off has a the 90 degree bolt pattern which is correct for my year model. I'll have the replacement one pulled tomorrow and it'll be interesting to see if it's the correct one. Fred, the torque converter guy @ PATC stated he hasn't seen a bolt pattern quality issue in his 25 years as a converter dude. My statement, there's a first time for everything. :-)
Edit: the symbols are stamped on the bolt pad side either between the pads or on the next flat surface towards the center.
So, they sent you the wrong converter... Ooops.
