Flexplate Question
Old Feb 16, 2014 | 07:18 PM
renardk764's Avatar
renardk764
Default Flexplate Question
One of the torque converter nuts is of center a wee bit. Is grinning the flex plate to widen the hole an option?
Old Feb 16, 2014 | 07:39 PM
No. Don't do that. take out the rest of the bolts, rotate the torque converter 90 degrees, and try again. It only bolts up one way. For balance reasons, it MUST be correct.
Old Feb 16, 2014 | 08:19 PM
renardk764's Avatar
renardk764
I went all the way around in 90 degree increments. No joy. I'll button everything up and give PATC a call tomorrow. Only thing that stinks is I'm working 80 hours this week and won't be able to tackle again this until next weekend.
Old Feb 16, 2014 | 08:26 PM
You have a 5.2 or 5.9 in there? Wonder if you got the wrong flexplate.
Old Feb 16, 2014 | 08:41 PM
AppelH's Avatar
AppelH
Should be the same flex plates dimension wise, just weighted differently right?
Old Feb 16, 2014 | 08:47 PM
renardk764's Avatar
renardk764
5.2. I'm thinking they sent me a 5.9 converter or their quality control took a hit.
Old Feb 16, 2014 | 08:49 PM
renardk764's Avatar
renardk764
flex plate is the original. Never changed. No weights.
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Yes flex plate is the same for a 5.2 or 5.9 the one for the 5.9 just has weights on it.
So you have tried turn the flax plate one hole at a time to see if you can get the holes to line up?
And as far as I know torque converters are the same too for both engines.
Old Feb 16, 2014 | 08:50 PM
renardk764's Avatar
renardk764
Yep. Must have went around 20 times hole by hole.
Old Feb 16, 2014 | 08:51 PM
You have a part number for the torque converter?
