spark plug heat range
Old Feb 17, 2014 | 04:30 PM
studders's Avatar
studders
Default spark plug heat range
Just have a quick question. I'm going to be changing the spark plugs in my truck in a few weeks and just curious what would be the best ones. I have always been using the original champion plugs. I was wondering if there is a higher heat range that I should go too. Someone told me that a higher heat range will help a little on fuel mileage. I'm also going to be doing a lot of towing this summer will a different/better spark plug help out with that. 1999 dodge ram 1500 4x4 5.9L thanks for any and all input.
Old Feb 17, 2014 | 05:24 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I still use Champions. I did relocate my ignition coil to the firewall above the distributor. Got rid of that 20 foot coil wire and all the stray misfires. I use a coil wire from a 4.0L Jeep engine.
Old Feb 17, 2014 | 05:32 PM
Now THERE is an interesting idea. Thank You.
As for hotter plugs, they are also more prone to spark knock.
Old Feb 17, 2014 | 09:35 PM
Ram Driver's Avatar
Ram Driver
You would be better off going one heat range lower, such as autolite 3923`s or what ever brand you prefer.
Old Feb 17, 2014 | 10:10 PM
moe7404's Avatar
moe7404
i have ALL WAS found the stock heat range is way to hot. on my 01 dak 3.9 stock, i went to a autolite AR3933 yes it IS a racing plug. have had the plugs for 4 mo. no trouble. but they may not be for you. judge for your self. when experimenting with very wild configurations run just one or two plugs at a time. so you can get home.
