transfer case 4x4 vacuum switch removal
Old Feb 18, 2014 | 02:13 PM
Jared_S2's Avatar
Jared_S2
Default transfer case 4x4 vacuum switch removal
How do I get the switch off of the transfer case that supplies vacuum to the actuator? I have tried turning it and it won't budge, I've pb blasted it and tried again, nothing. I am going to get a wrench 1 1/16" is what I read it is, but is there something I'm missing? I took a picture of it and it doesn't look like a spinning part but...maybe that's just all the rust. The vacuum isn't switching from the black line to the red line. I think the red line is to pull the collar off of the CAD, and the black is to pull it on the CAD.
Old Feb 18, 2014 | 02:14 PM
Jared_S2's Avatar
Jared_S2
I live in Erie, PA...there is always snow, I need help. I'm missing work because I can't drive anywhere. :/
Old Feb 18, 2014 | 02:27 PM
merc225hp's Avatar
merc225hp
It is just threaded into the xcase like a bolt.
Old Feb 18, 2014 | 07:00 PM
Spillage's Avatar
Spillage
Speaking like a bolt... what thread is the switch?... I might want to cut down a bolt and use it with an 'O'-ring when I pull all the vacuum stuff after installing a Posi-Lok cable.
Old Feb 18, 2014 | 07:55 PM
Arde's Avatar
Arde
Might not want to do that if the vent hose on the switch is for the TC, don't know if it is or not, but I suspect so.
Old Feb 18, 2014 | 08:20 PM
merc225hp's Avatar
merc225hp
I will have to get that info for you later, if I was to guess, 1/2"npt.
The vent hose for the xcase is not in the Vac switch it has it's own port almost right above the Vac switch.
Edit to add photo
231 on the left shows it above the Vac switch and the 241 on the right has it in front of the Vac switch.
