99 1500 4x4, violent shaking when braking
Old Mar 23, 2014 | 09:42 PM
xplorer82's Avatar
xplorer82
I am having similar issues.
I just got done doing shoes and drums on my 98 and now when I brake not only does it pull to the right Hard (after new front rotors, pads & calipers) I now have a hard shake from the rear.
Going to tear it apart tomorrow and see if I can find the cause. I will be keeping a eye on this thread tho.
Old Mar 23, 2014 | 10:11 PM
i4got68's Avatar
i4got68
Did you at all replace the springs and adjusters when you did the shoes and drums? I replaced my shoes, wheel cylinders, springs, and adjusters but not the drums where as they were smooth still and not rusted. Give those a try, it just might work.
Old Mar 23, 2014 | 10:46 PM
xplorer82's Avatar
xplorer82
yes I replaced all hardware (minus adjusters as mine were in good condition and spun freely), shoes and drums. I left the W.C's alone as they were not leaking or anything. bled the rear's right after.
I did keep having the ABS light kick on while bleeding. Not to sure what that means, but once I shut the truck off and fired her back up the light stayed off till we bled them again. Same thing happened when I changed front brake's and bled them.
Old Mar 23, 2014 | 11:25 PM
i4got68's Avatar
i4got68
Interesting, mine didn't have that problem
Old Mar 24, 2014 | 11:30 AM
I don't usually have the ignition on when I bleed brakes after replacing parts...... it just confuses things.
Did you replace the front brake hoses as well?
Old Mar 24, 2014 | 10:02 PM
xplorer82's Avatar
xplorer82
Me?
No I did not replace the hoses at that time. But I did run to advance and grabbed both today. got the truck off the ground, all four wheels off and checking things out really good. I see nothing strange really. It was my first time doing drums and shoes so I tore them all down tonight to re-do and make sure things are in place and correct. I did notice my e-brake lever spring/cables have a lot of play and push right against the adjuster spring at the bottom of the shoes. Is that a problem?
I know I need all new e-brake cables as mine are dangling and hanging right next to the gas tank. could that have something to do with the e-brake lever spring/cable problem..
And our brakes can be bled without the engine running? I thought it needed to be running. do you still get as much pressure as if the truck was running?
Old Mar 24, 2014 | 10:45 PM
xplorer82's Avatar
xplorer82
here is a few pics of what I was talking about..
Old Mar 25, 2014 | 09:14 AM
That shouldn't be a problem. (springs)
Without the engine running, the pedal *may* be a bit harder to push, but, I am usually bleeding brakes in a garage...... and kinda like that whole 'breathing oxygen" thing. (as opposed to carbon monoxide. ) Besides, it's good exercise.......
Old May 24, 2014 | 07:31 PM
norseman615@gmail.com's Avatar
Hello I'm new to forums ,This is my 1st drum/shoe replacement,I have pulsation in my pedal. I replaced drum,shoe,hardware (adjuster as well) and cylinder wheel. I engaged the parking brake several times to try to adjust the shoes after I encountered the pulsation.I was going to bleed the brakes again,but before I do I was thinking of seeing what you guys think. I didnt put the anti seize on the hard points on the backer , but I did clean them real good with brake cleaner.
I was also thinking that maybe I put the shoes too tight for the drum. I saw the responses about the drums needing be turned but I'm not sure the local parts shops do that (advance auto/auto zone).
Any thoughts?
(btw 98 1500 4x4 5.2)
Thanks guys
Old May 24, 2014 | 10:19 PM
Did you have the pulsation before you did the rears? If not, then turning the drums should take care of it. Need to find a machine shop, or garage that will do it for you. (just bring in the drums, shouldn't be more than 10 or 15 bucks each.... yeah, not cheap... )
If it was there before, take a look at the front brakes.
