Threaded heater tube hole on water pump ?
Old Feb 25, 2014 | 09:46 PM
jconlin's Avatar
jconlin
Default Threaded heater tube hole on water pump ?
Water pump is going out on my 98, I ordered the water pump that has the threaded hole for the heater hose off of rock auto, that was the only one I could get ahold of off of rock auto, that little heater hose has given me so many problems and has leaked forever, i just want to know if anybody knows what kind of fitting I need to get to make the hose connect to the pump, I am aware that I will most likely have to lengthen the hose, does any one know the size of that hole? Is it normal pipe thread? All replies are appreciated greatly
Old Feb 25, 2014 | 09:53 PM
Replace the hose, take the fitting out of the old water pump, and stick it in the new one.
Old Feb 25, 2014 | 09:55 PM
jconlin's Avatar
jconlin
The old water pump does not have a threaded hole but the new one does, the old one is just the metal tube with the o ring seal there is no fitting in the old water pump
Old Feb 25, 2014 | 09:57 PM
Two different holes. The metal tube with the o-ring is for the heater return line. Threaded hole is for the bypass hose between the pump, and the intake. If that isn't the case on your new pump, you got the wrong pump.
Old Feb 25, 2014 | 10:01 PM
jconlin's Avatar
jconlin
Hmm, maybe I read the description wrong, I know I put the correct truck in, I guess we'll just have to see when it gets here.
Old Feb 25, 2014 | 10:03 PM
Let us know when it shows up.
Old Feb 25, 2014 | 10:06 PM
jconlin's Avatar
jconlin
Here's the link to the pump: http://www.rockauto.com/catalog/more...913&cc=1314573
Old Feb 25, 2014 | 10:12 PM
The pic appears to be upside down, but, yeah, that's the right pump. Fitting already appears to be in the threaded hole. Should bolt right up. I use sealant on them anyway, as I don't like doing a job twice.
Old Feb 25, 2014 | 10:18 PM
jconlin's Avatar
jconlin
I ordered a nice felpro gasket set too, I'm sure the gasket set that comes with that looks kind a kindergardener cut it out, thanks for the input
Old Feb 25, 2014 | 10:23 PM
If you have close to, or over... 100k miles on your truck, you should do the timing chain and gears as well. It's about another 70 bucks for the timing set/gaskets..... and it was a MAJOR improvement on how my truck ran. You are only about six or eight bolts away once the w/p is out of the way.
